J
j.balde@att.net
The check engine light has been on for awhile, the code is: P0480 Cooling Fan 1 Control Circuit Malfunction
I replaced the Coolant temp sensor, the coolant relay, and the fan and fan motor. I don't know what else it could be. Maybe the Thermostat? I don't' know. Anyone else know what else it may be? or possibly how to solve it?
Well basically, right now, I have it hooked up to a toggle switch thats the only reason why it doesn't overheat. If I didn't then yes, the car would overheat cause the fan would not run at all.
