I have a Pontiac 2000 Sunfire and it runs really rough. I would like to check the
  • Thread starter Thread starter Alana J
If I remember correctly there is no port to check fuel pressure on those cars,
you would have to tap into the line near the fuel filter to check the pressure..
I would also check the filter and see if there are any codes for a missfire ..
sometimes you will get a clogging injector (or more) that will give you a random miss
or possibly even a bad plug or wire on the coil pack (they are not really wires) but the assembly has electrodes that sometimes go bad in the cover on the head ..
