i have a pontiac grand am gt i have a head gaset going bad howlong can it last...
  • Thread starter Thread starter brown6177
B
brown6177
...before it needs to be ? how long does can you hold off to get it fix
HOW LONG IS OK TO WAIT MY COOLING IS MIXING WITH MY OIL BUT NOT HAVING PROBLEMS WITH CAR NOT OVER HEATING OR ANY THING HOW LONG OF A TIME FRAME
haha i have a 97 probe that has a bad head gaskit. Go to a automotive store and get bar's leak put that in the coolant and that should help you out if not fix the leak it s like $40 a bottle but its worth it. Drain some coolant first so u will have room for it. just ask the people at the auto place and they should help you.
dont wait too long... or you will be up shits creek
they are not cheep to replace
please dont listen to the guy under me... you need to get it fixed asap. I work at a shop and i cant tell you how many times i see cars come in with blown head gaskets, then i see them leave in debt. because its expansive.
i would get it done as soon as you can!!! im serious... i dont wanna give you a time frame cause there really is no way you can guess without seeing it. and if coolant is mixing with oil, thats not good. so i would get it done quick
you can wait, you just gonna leak some coolant. depends how bad it is you might loose a lil compression but you sdhould be good for a while.
