T
tgangeltg
sunbird it is? it is dieing it starts right up after it is a 5 sp standard at first i thought it was the fule filter so i changed it i also canged the coil and ok hear is the list of things i have done
1. 2 wks ago i put a new clutch in no prob
when i drove it had a vibaration i did some looking and the cv onthe driver side is going out i have to wate on pay day to fix it
a short time later maby 3 or 4 day s the car strarted to rub ruff and miss and die so i ran coades and came up with 15 and 45
temp sensor and runing rich so i cleaned the o2 sensor and pulgs it helped the prob i drove the car for 1 and a half wks now the same prob only much worse i did the same and changed the fule filter now it has no effect last year i cange the 2 temp sensors allso . any way one month ago i put a new ecm in and it did run good till i canged the clutch i am out of ideas can any one help
