talon98.2.2sunfire
Hello all! new to the forum here.
So I drive a 1998 sunfire, about 190000 km on the clock, its a coupe, beautiful car engine idles smoothly, other than a loose motor mount sometimes you faintly feel it, runs beautifully, never stalled. lots of work done to the car as i plan to boost it in the future. it has a new map sensor, all new fuses for everything, new coolant temp sensor, new throttle position sensor, brand new exhaust system, new fuel filter, new fuel pressure regulator, all the tune up stuff wires plugs etc, not sure if it matters it has a sound system in it, new ignition control module and coil packs, you get the point. the pump works fine, i have had it tested and fuel pressure is nice and high, just to get that outta the way. the issue here im having is strange.
So. before all the work i did, its not as bad now but will still do it, when its hot out and i turn off the car, and maybe 45 mins later i will go out to restart it, it will crank for a while and slowly start to start up, if i floor the gas pedal it will instantly start. on cold mornings [ i live in canada and its winter here ] if i go to start the car, it will start and instantly stall, i found pumping the pedal helped it to stay on first try. this one seems to be worse when its frosty out, not just snowy. usually if its just snow its ok. i decided to go on the forums for this issue when i went for gas today and upon restarting the car, when the starter reaches the point where it wants to start the engine and its not cranking but just making that noise of the engine about to fire up, it sat in that position for a few seconds before actually firing up. this is making me nuts and i cant figure this one out. what could it be? also, if i turn off the car and instantly restart it, will fire up no problem.
