intake manifold bolts
rise474
Is there a special socket i use to get the intake manifold bolts off? None of my sockets work
Yes it is a 12-point 10mm socket that you need. They are available at most hardware and automotive stores. You can buy just the individual sockets. If you do buy one, you might as well buy the 13mm size as the same time. It is used on some of the suspension parts. These are the only two 12-point sockets you will ever need on a Fiero.
