I am a demolition derby driver and regularly use the 3.1L v6 Sunbird's (as I can run them with 4 cylinder cars). Great car and have always treated me well.
Anyways, I recently stripped mine down (hooked up my own fuel cell) and all seemed fine. I removed the entire dash and ever since then I have had intermittent starting problems. Sometimes it starts and runs fine, sometimes it will run and just shut off. You can hear a "pop" that sounds like a relay clicking from under the hood when it will not start (keep in mind I have spark and fuel). ABS light is flashing on the dash. The only code I'm getting is a 54, which is likely because I've removed the F/P fuse and cut the wires to stock pump.
Do you think I unplugged a vital connector when removing the dash? Or is it likely a coincidence that these issues started after removing the dash?
