marcusfiero
- Jun 16, 2012
Found a used Iron Duke from a 1989 Cutlass Ciera.
How much wiring etc will convert over?
Do we use the brain box from the Ciera or the Fiero?
If we use the serpentine belt how do we reroute the belt? The Ciera had a serpentine belt but the water pump pulley does not have any grooves on it and we do not need the power steering pump.
How/where do we locate the emissions equipment and vacuum canisters?
Is the newer injector better? Should we swap the injector/intake manifold and use the Fiero brain box?
Thanks
Thanks
