98sunfirecanada
- May 30, 2011
I have been battling a common problem with my sunfire for about a year and a half now. When the car reaches operating temperature the car will sometimes start to buck and miss when I let off on the accelerator, and when i slow down to a stop the idle surges up and down. When i shut the car off and restart it, it will be fine for another few miles until it starts doing it again.
Just last week i started getting a code P0404 (EGR Range) after it had been sputtering (after an hour drive doing about 80kms/hr), and this time the engine had even started to knock a bit and rattle.
A few days ago i removed the EGR valve off the car and inspected it. There was a bit of soot in it but not much, so i cleaned it out with throttle cleaner. I also cleaned out the tube that it bolts to.
A few days later i went for the hour long drive again, and began to get the same P0404 code.
Does my EGR valve sound shot?
I have noticed over the past couple of months that i hear a little bit of engine rattle (like lifters) when i climb a slight grade or when the engine is straining a bit. This is why i'm thinking maybe my EGR valve is shot.
Just on a side note: I have replaced the TPS, IAC, Coolant temp sensor, Map, Cam Sensor, Ignition module, coils, wires, and plugs.
(98' 2.2L Sunfire)
(98' 2.2L Sunfire)
