P
patrick
it is cracked
Not sure why so many folks are saying it is difficult. The 4-cyl is very easy as the engine is OHV. This means the only things to remove are the throttle body, intake manifold, exhaust manifold, and valve cover. There is ample room to work. It is best to lay a padded board across the trunk so you don't damage the trunk seal.
I've done them on 4-cyl Fiero's in about 3 hours.
Good Luck and let us know if you need anything else.
I think the main reason why people are saying this is because when you think about it. Your first time doing a head gasket way back in the day. Wasn't it a little more difficult then it is now? I remember my first head gasket was on a 1965 Ford Falcon Ranchero and it had the old 289ci block in it. that was the most annoying long pain in the butt job I had ever done. But now a days if you asked me to go flip that head off and replace the gasket. I'd be just fine no worries. I'll see you in four hours with a running car and an empty six pack.
Actually the first head gasket I ever did was on a 1969 Pontiac Catalina with the 400 ci V-8. It took me about a day to do it and it wasn't "difficult" but it was tedious in terms of I carefully pulled things apart and arranged them so I knew how to put them back. Now I could do it in less than half a day since I am familiar with how and where the parts go.
