Is it possible to install a second radiator fan to a 1996 Pontiac Grand Am Se 2.4L?
Openupacanof2000
My car runs hot and it seems to not leak or hiss like it did a few weeks ago because of a thermostat housing that was broken, so now that its fixed it just runs hot, it doesn't overheat but it runs on 3/4 of the temp gauge and up but never gets to the red zone and i've replaced the entire cooling system. knowing the size of this car is it possible to install a second one because it only has one fan, and i don't think that's enough.
But..
Clearly something else is wrong. The car isn't designed to run that hot, so something must be causing it to. Did your cooling system replacement include a new water pump? Have you considered getting a 'High-flow' pump?
