My grand am has had its fair share of hard to diagnose electrical problems.
Usually I've been able to easily find some record of others having this issue but not this time.
Issue is when I insert the key and turn, nothing happens; No crank noise, no headlights or beeping noises.
There are a few clues which may indicate what is wrong...
1. The power locks on the door do not function, neither does the key FOB.
2. The speedometer & RPM gauge needles on the dashboard are "floating", slowly jumping around to random values, even before inserting the key into the ignition cylinder.
3. I recently replaced the blinker switch assembly that is attached to the steering wheel, possible that some of the wires coming from these connectors got pinched somehow and created a short.
Obviously it might seem like the battery is the issue, but that was the first thing I replaced and inserting a brand new battery did not fix the problem.
Either way my grand am is currently at the dealership, as they are usually the only ones able to fix these weird electrical problems with Pontiacs.
If anyone has had an issue like this happen to them before please do let me know so I might pass it on to them to expedite the repair.
I will be posting an update after they fix my vehicle on what the resolution ends up being.
