Hello,
06 Pontiac Torrent AWD
I hope someone can help. I am starting to freak out.
About a year ago I had a odd knocking sound like metal hitting something creating a dull knocking which seemsed to be on the front driver side. Seems to be coming from teh floor area.
Only happens when I turn left and go over slight bumps.
Now it has gotten worse. So far I have changed the following:
both bearing hubs, both strut assemblies, both stabalizer links, stabalizer bushings and driver side control arm. Sound is still there.......
I did notice when I changed a few things that the driver side axle seems to be a little loose at the transmission. Does not seem to move enought o make noise.
My only other thought is a bad CV Joint. Maybe i need to replace the axle assembly. Before I do i want see if there is anything else I should check.
The bottom rear engine munt seems ok.
I am stumped. Please help.
