Leaking sunroof?
Blake06torrent
London Ontario Canada
Hello. So when theres heavy rain my sunroof leaks and the water comes out from the light and headliner. I clecked the drain lines and theyre clear. But i had an issue a ehile ago where the water got into my accelerator pedal connection and my car wouldnt drive over 15kmh. I dried it out and plugged it back in and it worked but im worried about future electrical problems occuring. And thats a nightmare. Im wondering if anyone else has had this issue and located where the water was coming in? Thanks alot
You blew the drain lines out with compressed air?
surely you've solved this problem by now, but I had same problem when I bought my 07' used last year. It ended up being the drain lines had come unhooked from the drain pans in the front corners of sun roof in the roof. I pulled the front part of headliner down to access both sides and reconnect them and hasn't leaked since.
