LEAKING
claudio
Member
Age
54
wellington ,south florida
Need help......
Have a 91 Trans-Am Convertible
Leaking under passenger side behind right front wheel.........
Smells like brake fluid but traced all brake lines and they are dry.....
Master is low but I need front pads.....
Line that is leaking looks like it goes to the tank on drivers side and ends behind right front headlight....???
did you remove the wheel and check if the caliper or rubber hose is leaking?
