lo beam head lights
milkyy
lo beam head worked fine. Parked van to have dinner when leaving lo beam would'nt turn on. All other lights work fine any ideas?
Either fuse,both low beams burned out,emergency brake on or didn't release all the way or headlight switch bad or relay bad?
You may have been driving around with only one low beam working, and didn't know. First thing I'd try is a known good headlight and see what happens. If it doesn't work, then it *may* be a headlight switch, probably best to see a mechanic and tell him what happened.
thanks i found that the plugs behind the lights were a little dirty. so i cleaned them and good to go.
