Looking for info on the Torrent GXP.
Rob8285
MI
So Im thinking next vehicle I buy will be the Torrent GXP. So here to pick brains. Pros, cons? How do ya'll like them?
any car with a limited production using parts not found in the base model should require very careful consideration before buying it. Do some research and find out for yourself the availability of parts such as shocks and struts. Also take into consideration the availability of any body components that are unique should you be unfortunate enough to have an accident.
If you need the power and can afford the premium for parts and maintenance, then definitely go for it.
