Losing Power While Driving
athompson7369
car is randomly losing power. Gas petal goes limp and doesn't work. Loses wire connection? Seems like a fairly common issue with this car. I don't think it is a fuel issues. The car loses power like the alternator is going down. Any parts know to fail and cause this issue?
Dealership Says.....
Dealership says it needs a new fuel pump. Has new fuel pump in it. Has to be a connection somewhere that is bad.
did you have the problem starting with the replacement of the pump?
Pump replaced, still has issue
Even after the new pump was put in I have the same issue. Took car back to dealership and they put Dielectric grease on the connect and that actually lasted awhile. Now they want to put a new pump in again.
