recently bleed rear brakes on 03 montana , have good pedal now but low brake fluid light is on and also brake light in dash , fluid is up to full mark and the brakes work great , what did i do wrong or is there now a new problem . reason for bleeding brakes were draggy/noisey brakes in rear and after repair had soft pedal hence the bleeding of rear brake cylinders ?
