Lowering Springs
When I picked up my 70 LeMans the rake was about flat. I've wanted to lower the front end. I'm to the point of replacing ball joints and I've decided to replace springs while its apart.
So, my question is, those of you that have put lowering springs in, have you had any camber adjustment problems? I'm not planning to replace the control arms and I'm planning to use springs that give about a 1 1/2" drop.
Thanks,
Mark
havent done it myself but you probably will have to use offset control arm bushings
