Maf sensor 2.4 engine grand am
roger6803
I have a problem my car does not have a maf sensor/meter, can anyone tell me if the grand am 1999 2.4 twincam 4 cylinder have one. And where is located. The 6 cylinder has one but the 2.4 ?
Can any one help. :d
Your car doesnt have one. You had the computer scanned and it mentioned a MAF sensor? What code do you have, PXXXX?
The 2.4 does not use a maf. The tune is speed density, do one isn't needed. Mainly goes off throttle position and manifold vacuum. The maf system uses actual air flow.
Maf sensor
Thanks for your replay it help me a lot, this is my problem.
My car every time i stop at a light, starts to chake a lot and some times it stop running. The computer code give this number p0134.
This codes tells my that the oxigen sensor bank 1 is bad or fuel presure is high or low check fuel pump.
I did both, change the fuel pump and change the oxigen sensor.
And still does the same thing stops running when a stop at a light or stop sign.
In autozone the sales person told me to clean the maf sensor.
So i look in my car and no maf sensor only the rubber housing and the enclosure where the maf sensor should go. Thats wy i ask for help. But still the problem exist. This are the new error codes that
exist in my car p0300, p0452 and p0134 again.
Can some help me . :d
