Ever since I've had this car the tail lights have been acting weirdly. With the housing on the right side sometimes the bulbs are equally bright, sometimes the bulb on the right is more dim (not a broken filament). With the housing on the left side, the left bulb sometimes glows extremely bright, and the bulb on the right isn't on, but sometimes the bulbs are of equal (not as intense) brightness. I tried checking the ground screw that's connected to the trunk latch system on the chassis and sanded it down and the area it sat on, and that didn't solve it. I was jiggling the wires for the left bulb in the left housing, and it changes the way the tail lights are lighting up, even effecting the housing on the right side. I tried to turn on the hazards, which usually gives the illusion of "wig-wags", but this time I noticed the green arrow on the right lights up first, then the left arrow lights up (within a fraction of a second), and then they just froze. The right turn signal functions properly, while the left one froze. I've tried looking it up, but to no avail.
