MontanaNoob
The wire from the hub(ABS sensor) got pulled out after something jumped into the wheel pit when rolling on a highway; i even lost power steering because it had also unplugged my hose from a connector that tied to the frame: that was quickly plufged back and fixed tiewraps effectively. However, there remains the ABS and TCS lights on in the dash because that wire got pulled out of the hub itself and also out of some other place I don't know some approximately 24" after the ABS connector that is next to the hub.
Piece of wire I've got looks like that:
===(3" of 2 small wires hub side)===(ABS hub connector male&female)=============(approx. 24" mire of wire that has some plastic shield engine side if i may say) green and white wires stick out of the latter end...
So once I’ll have changed my hub (cuzz I guess I can't reconnect the hub side part) il be able to plug it back with that connector, but where do the green and white wires get plugged into???
Thanks for any help, this is my first post here, I’ve always made all my repairs on my other cars, aside from engine or transmission.
Mike
Mike
