What are all the things I can check to fix an ABS and AWD Disabled problem? I've replaced brakes and rear bearings. The current problem is intermittent. Where is the sensor on the rear differential I've heard about? I'm told it has a filter of some kind that gets dirty. Could someone give me a general run-down of things to check? And where and how to check and clean or otherwise service these components, especially this differential sensor (which I've never seen -- perhaps that's my latest problem?)
Thanks!
Thanks!
