About 5,000 miles ago I rebuild my '85 GT and had it bored 30 over. Ever since, I've been having multiple problems with it. My brother and I have tried to work out the bugs with it but it only seemed to make things worse (never changed the gaskets, which is probably some of the problem). The parts that we have taken off were the Intake Plenum and the Throttle Body. Here are the problems that I have been having with it,
- Exhaust leak
(I don't know if this is because of a clog or if the gasket is bad where the leak is occurring. This exhaust piping has never been separated since the rebuild)
- High Idle
(This is one of the problems I believe is being caused by the gaskets)
- Backfire
(This could be caused by timing issues, I've used a timing light, but to little success)
- Burning too rich
(This is another of the problems that could be caused by the gaskets)
- Rough shift
(This occurred when I adjusted the distributor cap, after using the timing light. This actually caused the engine to idle lower by a couple hundred RPM's)
- No power
(I've had multiple issues with this. If I retard the timing enough it'll idle around 3k and have plenty of power, but it'll fowl plugs over time)
- Fowling plugs
(This could be linked to a few of the problems that i have listed above)
Any help would be greatly appreciated, Almost everything in the engine bay has been replaced, short of the vacuum lines, cruise control, and a couple other vacuum related components. And as I said, this motor only has 5,000 miles on the rebuild and I have way too much money in this car to just give up on it.
- Exhaust leak
- High Idle
- Backfire
- Burning too rich
- Rough shift
- No power
- Fowling plugs
