Hi my 88 trans am with a 350 TPI is running like crap!! I checked the fuel pressure it reads 42 psi with ignition on and i watched it for a while the pressure drops
to 30 psi within 5 minutes is this normal? I checked for codes i see a code 33,34 and 36 i did run the car with the maf disconnected to see if that would do anything
one of those codes may be due to that. When i touch terminal A to b to read codes most of the time the service engine light does not flash i need to play around with it to
make it flash and hear the fan come on what could this be? Other things i have done are cleaned the iac valve cleaned the throttle body i also cleaned the mass air flow sensor with sensor cleaner can you please guide me to what could be wrong? Any help would be greatly appreciated!!!
Thanks in advance!!
Thanks in advance!!
