My 2001 Pontiac Montana Cranks But Won't
  • Thread starter Thread starter mzbev4
If it cranks faster than normal it could be your timing belt/chain has broken.
also it could be the fuze to your fuel pump
check for spark , could be cracked distributor cap
clean off your negative terminal on the battery
let me know if this helped and good luck
Doubtfull it broke a timing chain.
Shouldn't have a distributer cap. Should be DIS with 3 coil packs. Could be a bad crank sensor.
I'm calling a bad fuel pump. Listen for the pump to turn on when you turn the key to the run position.
First 2 rules of no start are to check for spark and fuel pressure.
