My 2001 Pontiac Montana transmission was parked on a steep hill(with the...
itybtytityluvr
...parking brake),when I left the? Transmission started pouring fluid all over the ground. I was in a big parking lot and it left a mile long strip about 3" wide.
What could have happened?
How much will this cost to fix?
It is an 01 Pontiac Montana mini van.
Or you can have it filled back to correct level & as long as you don't park on any steep hills. You should be good. Most likely a seal, which direction was the engine facing on the hill? Up or down
sounds like it is your seal. depending on how much damage it took. maybe 300.00
