B
Bryan
...with it? I found out when I change the oil, turn out it was nasty jello mixed with oil, transmission fluid and an antifreeze mixed came out under the engine. It is head gasket cracked or an Intake Manifold Gasket Set that need to replace it? Some people said mostly like Intake Manifold Gasket Set, not head gasket crack because no sign of white smoke come out of pipe so they said Intake Manifold Gasket Set is more likely need repair. Anyone know the answer or what? Thank you so much for your time to read this question.
