My temp gauge has been jumping around for about 3 weeks and I am getting almost no heat. Last week the gauge went to max (past 260) and I had to stop 3 times and let it cool off to drive about 10 miles.
Went for the thermostat which is almost impossible to change after removing TB, air ducts and hoses from the TB heater pipe. When I took off the radiator cap found it covered with Dexcool Sludge. Replaced the thermostat and am almost finished putting back the parts removed to get to the thermostat.
The plastic petcock drain at the bottom of the radiator turned about 1/8 turn CCW and then the flat knob at the end broke off, Obtained a new one and will try to get the old one out either using a hot screwdriver or an EZout.
Need to try and backflush the brown sludge out of the radiator and engine.
Was below freezing here yesterday and today so I postponed the flush operation. Hope I don't have a blown head gasket as that is a real job to replace. Think that the problem is a combination of the frozen thermostat and the Dexcool sludge.
