My 2000 Trans Am has been sitting idle for a couple of months and everything was fine. After charging the battery, I started it with no problem, but I can't get it to rev at all, whether I'm in gear or not. Gas pedal doesn't respond at all.
If I put it in gear, it drives at idle speeds only. If I manually turn the throttle under the hood by hand, the engine revs just fine.
The pedal is not opening the throttle.
Any ideas???
Any ideas???
