My fog lights in my 2003 pontiac sunfire stopped working...
  • Thread starter Thread starter Bianca
B
Bianca
...:((? The other day I noticed that both fog lights are not working. Also the switch inside the car which turns them on has an orange light, and that no longer works either....Anyone have any idea whats wrong? Do I need to replace the actual lamps?
It sounds like you need the new bulbs. If the switch turns on to orange, that means, the switch is working, it's just that the bulbs are used up. I had the same problem once with my previous 99 Grandam, which got solved when I took it to the shop and replaced the bulbs.
If the light is out in the dash the fuse may be blown, I would start there the bulbs seldom burn out at the same time ..
