you can find a used one from a junkyard for very little, like $300-$400 or so probably. Then you just need a decentmechanic to install it and shops all charge different rates depending where you are. I had one done for about 500-600, or if you think you can do it yourself, which on a rear drive car like an f-body is quite easy, then you are set.
