Guys,
Oil is collecting on the bottom of the starter motor. So strange, as I cant figure out where it is seeping from. The valve cover gasket is clean. The shop manual shows the starter sprocket teeth above the rear engine seal so I dont think it the seal as one would also see seepage/oil draining all over the bottom of the flywheel, which is clean/no oil stains.
Where could this oil be coming from? Ideas welcome and appreciated.
