holsey82979
- Mar 26, 2016
Hello to whoever reads this..I am building a 428 .30 over flat top piston with 6x-4 heads.I had 16's but the cr was too high causing detonation.I am using these heads and 1.52 roller tip rockers,rpm intake,headers 2 1/2 exhaust,pertronix hei,and a jet street master 750 quadrajet. need info on a good camshaft(heard you cant beat the 068),stock converter or stall,headers or RA manifold,gearing,timing recommendations,spark plugs,best oil to use,and whatever else your wisdom can offer from experience.If I can get anywhere near 400 horsepower im good.I need too get this thing right this time.Its all in a 71 lemans.
Thanks
Thanks
