I need help with the origin of a Pontiac block.
I have looked at a Pontiac Trans AM 1970 RA3 with manual transmission (M21)
Everything with the car checks out except the engine block. When the current owner initiated a restoration of the engine, a crack was found in the original WS block, which was scrapped.
The owner has photo documentation of the engine restoration, which is based on a replacement block. I have spent hours trying to determine where this block originates from, and struck out. Based on the various casting numbers, this block seems to be non-existing, based on several visits on different websites with Pontiac info.
So, maybe you guys can assist me?
The casting numbers:
Casting Code = 9799914. Indicates a true 1970 RA3 block? (It is a 4 bolted block)
Engine Code = YD. According to the websites, no Pontiac YD block with 4 bolt mains?? The Y tells me its from an automatic?
VIN-casting = Above the engine code. Hard to read but seems to be 0040115. Does not match body VIN.
Displacement ID = Have not found any, either on the side of the block or in the lifter gallery. Since it is a 400 block, produced no later than 1971?
Freezeplugs = Three per side
Date stamp = Waiting on info from seller
So, what do you make of this? A 400 block stamped YD with 4 bolt mains and 9799914 as casting code? Is this some sort of replacement block from GM, or what Pontiac did it come from?
I really need some help! Info on these cars are scarce in Sweden where I live
