brewcrew
- Aug 11, 2016
Hello all, new to the forums, and have a question. Hopefully someone is able to steer me in the right direction.
I recently got a '69 Le mans, with a Pontiac 400 in it, bigger cam (not sure what).
The vehicle was redone 18 years ago, not sure how much it was drove in the last 4 years.
The vehicle runs great when cold, idles fine, it heats up and that's when it seems to have a surging effect. I can be cruising at ex. 35 mph and the car seems to wanna lunge forward, hit the gas and it bogs a bit and takes off.
I replaced the plugs, wires and fuel filter, ran the vacuum advanced line.
Ignition coil, condenser readings are in the proper range. Cap and rotor are fine as well.
After all of this I re-did the timing and it seems to run really smooth, until it warms up and gets the same effect.
Do I have the carburetor adjusted wrong, or maybe it needs to be taken apart and gone through, not sure.
Hopefully someone with more knowledge can help me out
