Need Some Guidaance
T/A
I have a 1994 Pontiac Firebird Trans Am. I posted back in March that my alternator went out but that is not the case.
My car has a brand new computer system in it, starter and the starting electrical system has been tested and everything is fine BUT something is draining my battery. Every time I start it up it has to be jumped and when turned off the next day my battery is dead and when I do get it running it's still pulling from the battery.
If someone has any ideas please let me know. I am up for any ideas on how to get my car running again.
Using a voltmeter check the draw on the battery when the car is off. If you have a parasitic drain you should see it on the meter. Then start pulling fuses one circuit at a time till the draw goes away. Once you find the circuit you will have to look for the cause.
