K
Kayleb D
...water out of it.? ok so where you pour the oil in to fill it up and it was told to me that its the timing chain cover that is the big cover it goes into. well right on the bottom side of that there is a piece that bolts onto the bottom of the timing chain cover with a few bolts and then bolts onto another piece right under my manifold where it comes out the back of my enigine. that little piece looks to be metall but it has avery slow drip of about a really slow dripping water facet but it leakes about a gallon of coolant a week and it looks like the piece has as little hole in it and i put black silicone sealer on it when i found the hole and it slows the leak down but hasnt stopped it. i dont know what this piece is called or if its a very important piece that could cause me alot of problems if not fixed cause im fine with the leak i just put more water in my coolant tank and its good to go. if you know what this piece is called or how i can fix this anything would be appreciated. so just tell me all the parts that are in that area that it could be and ill google them and see which one it is thanks!!!
