New headlight switch causing park lights to flash
98sunfirecanada
Hi there,
I was having the problem with my headlights a while back (where the low beams wouldn't work, but high beams did). The wiring was all replaced up front and re- routed. I had also replaced my headlight switch in the process.
The issue i'm having with my new switch is that when the car is cold and i turn my headlights on, the dash lights and all my parklights go out. If i flick my high beams or use my turn signal they come back on, and then go out when i let go of the lever.
It only seems to do this when the car is cold. After it is warm everything works fine.
I'm just afraid someone will run into the back of me some night when my parklights don't illuminate the back end of the car!
Has this ever happened to anyone on here? The switch is brand new out of the box.
Thanks
