Did the car have a history of low power before you replaced the ignition module? If it had low power before, then check for a clogged cat. convertor.
If the low power is just since the module replacement. Then double check that all things are plugged back into the module, no bent terminals, scan for codes. Did you use a quality brand ignition module?
