New Owner Help
91Bird5spd
York
Hello, im a proud new owner of a 1991 Pontiac Sunbird 2.0L 5 Speed. I just bought this car and it seems to have a miss or something of that nature during acceleration and it also seems to throw on the check engine light. Also the electric cooling fans come one only after a mile or two of driving. Really frustrated with this missing and acceleration problem. Any help would be greatly appreciated. Thanks, Dave.
find out what code the check engine light is indicating
thats the thing, it only stays on but a minute or two. then by the time i get to autozone to check it, it goes off.
If the light came on, there should be a code stored.
autozone said they cant scan it bc its obd 1 not obd 2 so what should i do?!?!?
You can jumper the a and b terminals in the aldl port under the drivers side dash. the cel light should falsh 1 2= 12 then the code. 3 falshes plus 4 flashes = code 34.
so your saying that when i jump the a and b terminal ports that however many flashes it does then pauses then flashes again= the code number?
Yes, get the code(s). Then Google is your friend.
