TOG1937
Member
- Feb 4, 2020
A mostly original survivor car right down to the original points distributor, "GM" 2 bbl Rochester carb and original air cleaner. Engine appears to be matching numbers. Fuel pump appears to have been replaced not too long ago. We replaced the 3/8 fuel line to and from the mechanical fuel pump and installed an in-line fuel filter ahead of the carb. The fuel filter never even come closes to filling but the car runs great and strong.
Any reason to be concerned about this?
Anyone know what the correct light bulb is for the rear courtesy lights in the lower door cards?
THANK YOU!
The Old Guy
THANK YOU!
The Old Guy
