- Apr 25, 2005
Filed under: New York Auto Show, Sedans/Saloons, Pontiac
Click above to view more high-res live shots of the Pontiac G8 GXP
It's a rare occurrence when honest applause breaks out in a press conference over a new model, let alone a transmission. But that's exactly what happened when Maximum Bob talked up the Pontiac G8 GXP, and specifically its optional six-speed manual transmission. Mated to that highly coveted cog swapper is the 6.2-liter LS3 V8 pulled from the Corvette, making 402 hp and 400 lb.-ft. of torque. If you opt for the 6L80 auto 'box, you can check your manhood and an extra two lb.-ft. of torque at the door.
In addition to the upgraded engine and manual tranny, the GXP benefits from the 19-inchers originally shown on the G8 concept, Brembo brakes (sized 14-inches up front and 12.76 inches out back) and some revised suspension bits. Zero-to-60 times are down to 4.7 seconds and the G8 GXP (along with the Solstice coupe and 'ute) are all due to hit dealers later this year.
Pontiac's full press release is posted after the jump, and our own live high-res shots can be seen in the gallery below (we're going to be adding more as soon as the pandemonium surrounding the vehicle dies down.
Gallery: 2008 Pontiac G8 GXP - Live Reveal
Continue reading New York 2008: Pontiac unveils G8 GXP, featuring 50 Cent [w/VIDEO]
More...
It's a rare occurrence when honest applause breaks out in a press conference over a new model, let alone a transmission. But that's exactly what happened when Maximum Bob talked up the Pontiac G8 GXP, and specifically its optional six-speed manual transmission. Mated to that highly coveted cog swapper is the 6.2-liter LS3 V8 pulled from the Corvette, making 402 hp and 400 lb.-ft. of torque. If you opt for the 6L80 auto 'box, you can check your manhood and an extra two lb.-ft. of torque at the door.In addition to the upgraded engine and manual tranny, the GXP benefits from the 19-inchers originally shown on the G8 concept, Brembo brakes (sized 14-inches up front and 12.76 inches out back) and some revised suspension bits. Zero-to-60 times are down to 4.7 seconds and the G8 GXP (along with the Solstice coupe and 'ute) are all due to hit dealers later this year.
More...
