Hi all,
In trying to fix a brake problem I have created a worse issue. I replaced my powerbrake booster. I removed battery and box, I then unbolted the fuse box and tilted it forward, did not disconnect the wires, I did this when I replaced the master cylinder with no problem. Removed the master cylinder and the abs pump etc. Removed the power boost the fuse box was moved but was careful not to strech the wires, at least I thought so. reassembled everything. Went to start the car the dash lights up but when I move the key to start I get nothing. Lights, horn, radio, windows all work just no crank. I have fully charged battery with power going to fuse box. I changed the crank relay didn’t help. I don’t know where to start checking throwing money at it won’t help since I don know what’s wrong. Any ideas where to start all dash lights light up after a minute or so they go out and the stabilatrack light stays on. My code reader will not talk to the system,it reads then says error. This is the first time I have ever had to deal with electric issues and I am quite lost. Any help would be greatly appreciated. Also can someone recommend where I can get a good shop manuel Something better than a hanes book that I have. Again thank you for help.
