No Low Beams, All the rest works fine???
bojanglespa
2000 Sufire GT. This is my son's car and I noticed that he had no low beams the other day. All fuses are OK and the bulbs are ok as well. I tested the 3 wires going to each bulb when low beams turned on and I had power to all 3 wires right at the plug but no light up of the bulbs. Should there be power on all 3 wires, is not one of them a ground??? I will remove the washer bottle and LH headlight and check the splices later but was wondering about the power on all 3 wires being there, If there is power why no light....
High beam OK, Fog Lights OK, DT Running OK, Park lights all ok as well.
It was the muti function switch that was at issue. I picked one up from the wreckers and it works fine now....
Low Beam Problem
Had this same problem in my '96, after trying a few things I found a reasonable new turn signal (cruise control, etc) switch and that did the job. I guess they just wear out? About 6 to 8 different screws behind the steering wheel, not bad at all to put in. I think I paid about $30 bucks for it on Amazon?
Good Luck
