Grandam1986
- Aug 28, 2020
Hi all. So one day I had a evap code. I went to look at this 8 pin connector under the car to see how that was well all the pins on the connector were green and bent so I try to bend them out just plug it back in and forget about it. Van still ran until the next day. tried to start it back leaving the gas station and nothing. So I kept cranking it some how it started after multiple attempts got back to work I shut it off started again. Then leaving working it started but once I hit a little bump it shut off and won't start back up. I basically bypassed that connector for fuel pump and wired the fuel pump to the top wires behind the drivers seat. Still getting no power. Maybe bad fuel pump? Im at a loss
