gatorcountry
- Mar 4, 2015
I'm new to the forum so hello to everyone from Florida! I recently aquired a 1990 firebird formula, 5 liter 305 TBI. the previous owner told me it was not getting power to the fuel. After double checking the fuel pump and ensuring it runs with 12 volts hooked to it I then replaced the fuel pump relay only to realize im not getting power to the fuel pump relay. I then replaced the oil pressure switch which supplies power to the fuel pump after the engine has 30psi of oil pressure, still no power to the pump relay and obviously then to the pump itself. Am I correct in thinking the relay gets power via a wire from the ECM? I know the line has a fuse for the fuel pump in it which I checked and the 20 amo fuse is fine, does this sound like the symptoms of a bad ECM or possibly the security system shutting power off to the fuel pump? As far as the security system goes I think it is fine because when the key is turned to the on position the security light on the dashboard lights up and then goes off after 3 or 4 seconds, which i've read means it is working properly, any help would be greatly appreciated. Bad ECM or any other leads? Thanks in advance eveybody!
