It starts and runs but has backfire on idle. Slow revs I’ve changed fuel pressure regulator no change camshaft position sensor no change I have crank position sensor haven’t put that in yet. I have ignition on cylinder 2 and 4 but not in 1 and 3. But I do have fuel going to all cylindersUse this link
How To Troubleshoot A No Start (GM 2.3L, 2.4L Quad 4)
GM 2.4L (Quad 4) Index of Articlestroubleshootmyvehicle.com
So why not follow the no start diagnosis it may point out something you missed? ICM, bad coil, etc.?It starts and runs but has backfire on idle. Slow revs I’ve changed fuel pressure regulator no change camshaft position sensor no change I have crank position sensor haven’t put that in yet. I have ignition on cylinder 2 and 4 but not in 1 and 3. But I do have fuel going to all cylinders
Tested coils both are at 1.5 & 1.6. Had icm tested as well. It’s healthy. I’m getting a lot of ignition coil housing replies other places but idkSo why not follow the no start diagnosis it may point out something you missed? ICM, bad coil, etc.?
