bergie1985
- May 27, 2012
Hi there, first post hope it all goes well. I have a 2004 montana 3.4 engine not awd problem started about a week ago, start van and all is good, no mil light, you can drive it or let it idle but as soon as it hits like 2 notches below halfway on the temp gauge it stalls out and cannot restart until it cools off, pulled the front 3 plugs out and none were getting spark, swapped ICM from a venture we have out here and have the original tested at NAPA and problem persisted and the ICM tested good. I have also replaced the crank position sensor and did not help either, plugs and wires are recently changed. Help with this would be awesom, has an appointment with the dealership on wednesday and i would really not like to take it there. Thanks in advance
